ORIGINAL: Countryboy
Fabio,
OK, measuring back from the leading edge of the fuse root section to the center of the wing tube, I measure 273mm. The same measured from the back pointed edge on the fuse root measures out at 330mm. The distance from the center of the tube too the top of the fuse measured out at 17mm. The distance from the center of the wing tube to the center of the retract strut measures out at 87mm.
One interesting note, I was able to get the exact same measurement on both sides when measuring from the pointed ends at the back of the fuse to the center of the wing tube, but had a 4mm difference side to side when measuring from the leading edge... the left side being the longer of the two. You don't notice this unless the wings are butted up to the fuse with the fins removed.
ow..perfect!!
This that I needed! Now I can continue the work.
Thank you Countryboy!!
Fábio
"I love RCU forum!"
