RE: Engine con rod rubbing
If that doesn't fix it , you may have to look at getting another backplate( thinner) or removing some of the metal off your old one with some wet and dry. It obviously ran a little like that so it cant take much to get it freed up properly.
I definitely make sure that the crank IS all the way forward first though.
