RCU Forums - View Single Post - How To: Calibrate your Accu-Cycle
Old 01-31-2005 | 09:19 AM
Juice
Default RE: How To: Calibrate your Accu-Cycle
Does anyone know why you must select 1 cell???
See [link=http://www.rcuniverse.com/forum/fb.asp?m=1527003]Post #6[/link] of this thread for the answer.
I notice the 18 & 20 mah in the pic but wouldnt this be time or compacity of the battery once discharged depending on what you have the selector switch on. Could you explane more of what you mean by " I used 18 & 20 to adjust the discharge rates". I'm lost there.
The 18 and 20 mAh really has no relevance to the procedure. The Accu-Cycle is in discharge mode when you are doing the calibration. 18 and 20 mAh is how much the batteries partially discharged while I did the calibration, expressed in mAh. Assuming a constant discharge rate of 250 mA you can also express this in time:
18 mAh / 250 mA = 0.072 hours = 4 minutes 19 seconds to calibrate RX
20 mAh / 250 mA = 0.08 hours = 4 minutes 48 seconds to calibrate the TX
Again, this has no relevance to the procedure. Everyone will take a different amount of time to calibrate their charger.
Hope this helps,
Juice
