RCU Forums - View Single Post - Help, elevator servos running at different speeds!
Old 01-31-2005 | 09:30 AM
colled
Default Help, elevator servos running at different speeds!
Hi all,
I have installed two Futaba 3010's in my funtana 90 elevator halves, one on each side. The problem I have is that one side is slighly faster than the other, but only when moving the elevators up. When moving down they seem to be the same speed. Obviously this will cause a slight roll to occur when quickly applying full up elevator, such as pulling a wall or parachute and I'm keen to sort this out. I was wondering whether this is likely to be a software problem with the mixing on my FF9 tx or whether the servos really are running at different speeds. Anyone come across this before and have any ideas on how tol fix it ?
