RCU Forums - View Single Post - Aerobird push-pull rod conversion help
Old 01-31-2005 | 12:43 PM
Old Man's Avatar
Old Man
Default RE: Aerobird push-pull rod conversion help
I have seen similar planes with the push/pull rods but my biggest concern would be that if the wire is small enough to make bend down thru the fuse and then bend up again to the control horns, will it be stiff enough to push the control surface during high speed flight.
Give it a try but keep the speed slow and slowly build up your speed until you know that the wires are stiff enough to push the control surfaces.
