RE: Splitting a Sliding Canopy- How to Cut?
A razor saw, the kind with the wide blade, is probably the best for this kind of work. It makes a thin cut that does not remove much material and the wide blade keeps it from wandering. Work slowly and all that should be needed is light touchup sanding of the cut surfaces.
