RCU Forums - View Single Post - dark oil problem
Old 01-31-2005 | 02:16 PM
Montague
Default RE: dark oil problem
Also be sure to check the joint between the front and rear halves of the muffler. The muffler might be tight to the engine, but the threaded rod holding the muffler together might be loose, causing the black gunk (as metioned above, bits of metal)
