RE: Bubbles in Monokote What went wrong?
Peter,
Take a very small pin and poke a hole in the bubble, then heat away. The most common reason why a bubble travels is because there is no where for the hot air to escape. Also It is not uncommon the have to go over the edges of the covering with an iron to make sure that it is glued fairly well before using the heat gun.
