RCU Forums - View Single Post - Help, elevator servos running at different speeds!
Old 02-01-2005 | 10:51 AM
njl
Default RE: Help, elevator servos running at different speeds!
Have you tried swapping the servo's leads around in the RX. Does this make the other surface go slow instead?
If it does then it something to do with the TX/RX. If the slow surface stays on the same side then it is is the servo or the linkage causing the problem and not the TX/RX.
Nick
