RCU Forums - View Single Post - Help, elevator servos running at different speeds!
Old 02-01-2005 | 02:20 PM
Stew99
Default RE: Help, elevator servos running at different speeds!
I believe I read one time that the cause of the lag was the fact that the servo channels are processed sequientially so if you set up dual elevators on 2 and 8 then it has to process five other channels before it gets to the second elevator servo. It this is true, you should be able to reduce the lag by using adjacent channels for the dual elevators but then you would have to use custom mixes and reassign some of the other controls. I have not played around with this to see if it works.
