RE: gyro handling in sharp turns
Hi,
I have two sets of rotors, all from the same mold, and I bolted one set on a hub to turn CCW and the other set on a hub to turn CW. After several flights I determined that the gyro turns better to the left with the CCW blades and it turns a lot better to the left with the CW rotation. With the CW rotations, I had to help turn the gyro with rudder as the gyro had a hard time turning right by just tilting the head. I suspect it's because we're north of the equator!
Phil
