RCU Forums - View Single Post - Which engine for Waco bipe?
Old 09-08-2002 | 02:32 PM
OUTCAST
Default Which engine for Waco bipe?
If you want to run gas, look at the RCS 140. It will have no problem with the 18-inch prop and will give you that "gas" sound. From what I have seen they produce about 15 pounds of thrust giving you better than 1-1 thrust to weight. They are only slightly heavier than the same size 4 stroke. The RCV would be my choice of the two you listed.
