RCU Forums - View Single Post - Help, elevator servos running at different speeds!
Old 02-02-2005 | 09:14 AM
colled
Default RE: Help, elevator servos running at different speeds!
I'll have a go at moving the elevator channels to something like 7 and 8, rather than the 2 and 7 it is on at the moment and see if it does make a difference. If so then, it would indeed inidicate that the channels are processed sequentially in order and the wider the spacing, the more noticeable the difference.
Yeah I'm using about 45 degree movements for 3d, which is why I find it noticeable. Although the slower elevator probaly catches up within a fraction of a second, I find it very noticeable and I'm sure it must have some effect on the plane acting like an aileron to some extent.
I guess digital servos that allow speed programming would get around this problem as well, I think Hitec's are.
