RE: HobbyZone Firebird Scout
The Scout is a Zone 1 skill level plane, so no experience is necessary to fly it. HobbyZone’s Smart-Trak™ control system gives you two ways to fly: Standard Mode and Expert Mode. If you’ve never flown before, Standard Mode keeps turns smooth and responsive without allowing you to turn too steeply. After you’ve mastered the basics, you can unlock Expert Mode for tighter turning performance.
Specifications:
[ul][*] Wing Span: 29.5 in (750mm)[*] Overall Length: 21.7 in (550mm)[*] Flying Weight: 5.8 oz (165g)[*] Motor Size: 180 power[*] Radio: Proportional 2-channel FM with Smart-Trak[*] Trim Scheme Colors: White wings and body with orange and deep pink decals[*] Recommended Battery: 5-cell 6V 300mAh Ni-MH[*] Approx. Assembly Time: 5 minutes[*] Transmitter Range: 1500 ft (457.2m)[*] Available Frequencies: 6 frequencies on 27 MHz[*] Smart Trak: Yes[*] X-Port: No[*] Charger: 2.5-hour wall pack with optional DC peak (HBZ1026)[*] Landing Gear: Yes[*] Steering: Proportional
[/ul]
