RCU Forums - View Single Post - Poulan 42 test run
Old 02-02-2005 | 04:54 PM
mikenlapaz
Default RE: Poulan 42 test run
when rotated to topside needles the diaphram vent will be direct in prop wash. Check your rpms with a shield between prop and carb. Had one that did not want to turn up after rotating carb. Be interested to see if it affects your rpms
