RE: Having a CG problem...Help?
Besides having free movement in the ball and socket joint you also need to remember to turn off any ceiling fans and make sure the AC/Heat duct is not blowing directly on the plane while balancing.
The advantage of using a CG Machine over fingers is you are able to add small amounts of weight till you get it right without constantly relifting the plane.
Ed M.
