RCU Forums - View Single Post - Help, elevator servos running at different speeds!
Old 02-03-2005 | 03:17 AM
colled
Default RE: Help, elevator servos running at different speeds!
Unfortuantely if I use the ailervator function, I can't use any other wing mixes and I like to have flaperons and spoilerons setup as well, so I normally just mix the elevator channel 2 with an aux channel like 7 or 8, which is effectlively what the ailervator function does anyway. However, perhaps the ailervator function recognises the fact that you want both elevator halfs to move at the same time and gets around the sequencing problem covered above. I haven't tried so can't confirm, anyone ?
