RCU Forums - View Single Post - Skymaster BAe Hawk Fuel system
Old 02-03-2005 | 06:28 AM
Miniflyer
Default RE: Skymaster BAe Hawk Fuel system
Ali, i will take pictures of the instrument panel tonight when i get home.
As for the landing light, pictures will be until i get a chance to visit the plane again. But the basic principle is fairly easy: A 1W luxeon emitter (available through conrad electronics for instance) with a larger custom heating conductor is placed in a MagLite flashlight mirror. Diameter is about 2cm (rough guess). I heated a butyrate sheet in the oven and pulled it over a plug to fit the Hawk nose. Cut off the nose cap, install it and off you go. We were afraid of using the 3W or 5W emitters, as they produce enormous temperatures and would probably melt away the mirror if our heat conductor doesnt work the way i plan. Might try them if the 1W holds up fine and the temps we are getting remain in the ok-range. I'll keep you posted on this, and will get the pics to you asap.
Nice looking hawk, by the way. That airbrush look sparkles out a lot . However, it is not quite scale...the real thing had sharp lines as i recall....
[link]http://www.jetphotos.net/images/j/JetPhotosHawk2.jpg.11814.jpg[/link]
Regards
Miniflyer
