RCU Forums - View Single Post - Pull-Pull vs. Pushrods
Old 02-03-2005 | 07:25 AM
sjc115
Default Pull-Pull vs. Pushrods
I am going to be building a hybrid fun-fly type plane (the Wacky Bee III from HSRCM http://www.hsrcm.com/) in the next couple of weeks. Right now I am getting all of the materials together and I am debating if I should install Pull-Pull controls or go with pushrods.
If you look at the plans you will see that the servos are mounted in the aft portion of the fuse, making the distance from servo to control horn fairly short. The designer recommends a pull-pull setup.
I did a search and read a lot of posts about pull-pull setups on this board, but I am still undecided on what to do. I have never installed a pull-pull setup and I am just wondering what everyones opinion on them is. Are they worth the time and effort? Or, for a model like this one with such short distances between servo and horn, would it make more sense to just go with a nice stiff pushrod?
Any thoughts on this subject are appreciated.
