RE: Trying to trim out k/e coupling
Also remember that Rud>Ele mix is not liniear. The mix is speed senasitive. the fast you fly the less rudder required the slower you fly more rudder is needed. As you increase rudder the mixing percentage changes. Some people do this mix on a curve mix so they can compensate for the amount of rudder used. Others use a linear mix and try to fly at the same speed.
