RCU Forums - View Single Post - engine wont start?
Old 02-03-2005 | 12:23 PM
Grantothismo
Default RE: engine wont start?
1) Has your truck been broken in
2) does it crank
3) did you remove the oneway bearing and put it back in wrong
4) does it even act like it wants to start
5) is fuel getting to the carb
6) have you ever cleaned your air cleaner
7) do you know anyone that can tune an engine
8) does the fuel enter the carb (take aircleaner off blow into pressure tube)
9) are you sure the glowplug is good
10) how cold is it when your are trying to start it
11) did you try to warm the engine with a hair dryer before starting
This is a good start.
