RCU Forums - View Single Post - Throttle Curve, Yours?
Old 09-09-2002 | 01:47 AM
JRozman-delete
Default Throttle Curve, Yours?
Wayne, go to [PROG.Mix1] and input THRO>THRO. Then you can set the points and curve at 25% travel intervals. This option is only available on Mix 1 and 2. (Multi point) At Point scroll to L set, then 1 set and so on. I set the mix to be on at all times so as not to worry about switch position. If you have any more questions, fire away.
Jess
