RE: Help, elevator servos running at different speeds!
OK, I'm having some deja vu here, I hope we are talking about the same things. I have a Futaba 8 channel radio. On a typical plane, with 2 aileron servos, two ele servos, two rudder servos:
I have the flaperon function turned on to tie the 2 aileron servos together. You can set up the flaps to drop with a switch, or see below.
I have the elevator halves tied together with the ailevator function.
I use the two 5 point mixes to set up flaperons and spoilerons (elevator to flap mixing).
I use a P mix to tie channel 4 to 7 for the two rudder servos, and another p mix to turn off the channel 7 knob.
if you dont have a progamming book (beyond the instruction manual) I'd recommend you buy one, I've found it to be very helpful.
peter
