RCU Forums - View Single Post - Spoilers/Spoilerons
Old 02-03-2005 | 08:19 PM
raideron's Avatar
raideron
Default RE: Spoilers/Spoilerons
Hi all.. I'm not sure if this has anything to do with this thread but....
I have tried flapperons on my 4*60 which it did not do what I wanted
to use it for(flat spins)... the flaps, tho not needed on my 4*60, worked
great.. Anyway I was finishing up on my used UCD 46, trimming all, range
check etc.. and had both elev. and ail. on dual chennels each and all
was looking good except my throttle cut, it was not working right.. No
movement off of low throttle, but it would move while the sticks was in
the high throttle position. I thought all was set right on my Airtronics RD
8000.. Anyway I gave up and called Airtronics and explained my problem..
he right away said you have spoilerons activated, deactivated the
spoilerons and activate flapperons and all should work.. And they did...
Just thought I'd post this for those that may have the same radio and
the same problem... Thought I give my used UCD it's first flight with me,
but No Can Do.... My tanks is leaking.. Hopefully I can pull the YS-63
and just tighten the tank screw.... I'm hoping it'll work... If not have to
wait for a new tank...
