RE: Genesis owners... how is the engine?
Maybe a good time to throw this out their.....
Check out a 4-stroke? 2strokes produce their max horsepower at two high of an rpm, especally if you're using it as a crawler, you will need an engine to produce all it can with minimum thorottle.
With that, mini 4 bangers Are pretty fuel efficient, and they will produce the torque you need, at the rpm you want.
