RE: RealFlight G3 Basics - Newbies apply here
I understand your, RFG3, need to provide a secure method to thwart copyright infringement, but to not allow the joystick ability to fly the sim is a problem for a number of users.
It seems that if you force the end user to config the RFG3 with the G3 TX serial and the serial from the code and then verify that it is a legal copy - proper registration and all, then the code shoulod allow for the ability to use the joystick if needed, to fly.
Also why can you not built an USB interface cable with the hardware lock built in it and then provide adapter cable to the different Tx connectors?
Just ideas...
Chasman
