RCU Forums - View Single Post - Readings on my tach
Old 02-04-2005 | 01:37 PM
Montague
Default RE: Readings on my tach
The color of the prop also matters, depending on the lighting situation. If you have a black prop, you can try painting some white stripes on the back of the blades. If it's a grey prop, try white or black paint.
I'm not sure the tachs pick up blocking the light, so much as changes in the lighting. If your back is to the sun, you might be counting "reflections" as opposed to shadows, for example.
