RE: Flair Puppeteer Trust Angles
Yes those are Flair floats. They are foam with a wood veneer, and I glassed them with 3/4oz glass and finishing resin from the local hobby shop. If you search for flair on the internet you will find a couple of US dealers that handle Flair. There is no need to alter the airframe as they attach to the existing landing gear slots.
The engine is a PAW 60 diesel, that I got from Carlson engine imports in AZ. Eric Clutton (DR. Diesel ) sells them also and he is in your end of the country. I was looking for more power and did not want to cut the cowl, and was interested in diesels anyway. It has a different sound and will swing a large 15-8 prop, which I think works well on the Pup. Dr. Diesel says that diesels don't smell bad, they just smell different!!
Randy
