ORIGINAL: ChrisAttebery
When the switch is up the airbrake function is activated. When it's in the middle position the flaps and airbrake are disabled. When it's in the down position the flaps alone are activated. I don't think I will use the flap to elevator mix. The 7C CAN NOT do the aileron to flap mix.
You do have to enable the flap trim, but I set it to 0%.
I have the ailerons on 1 and 7, the flaps are on 6 with a reverse Y, and I'm using 5 for my remote ignition switch.
Chris
Similar to what I did except I did not have a y reverser so used a mix for flaps. Did not have a remote ignition switch.
I was not able to do the flap to aileron mix. Futaba sent me a note telling me how to do it but I never got to try it and lost the note to a virus. You know for a fact that it can not be done?
Jim
