RE: China Model Productions O-1 Bird Dog in VNAF Finishing and Flying
There were other VNAF schemes, mostly similar to yours. The checkerboard pattern is specific to the 112th Observation Squadron, VNAF, based at Bien Hoa. I have pictures of several of the planes from this squadron, but none with your tail number. A lot of the planes are Olive Drab instead of gray. The USAF used the dove gray, the Army used O.D. green. There were a few Air Force birds in green, and a few had several different camo patterns. The Army had a couple of camo patterns but mostly the green. The problem with camoflage paint was that the fast-moving jets that were being directed by the Birddogs could not see them against the foliage. The Air Force added a bright orange stripe across the top of the wing from tip to tip, and a panel behind the rear window to the vertical tail, but eventually changed them back to gray. Here's a picture I found, that might interest you, from just after Korea. The 82nd Airborne experimented with this. I say you'd have to be bona fide crazy to do it, but imagine the ride!
