thinning epoxy
When mixing epoxy to fuel-proof a firewall, should you add something to thin it out ?
I think I remember reading in a post that you can mix in a little bit of alcohol and get good results...
Is this true ?
The last time I put a coating of epoxy on a firewall, I used 15 min epoxy and did not thin it with anything.
It seems to be a little thicker than it needs to be.
