RCU Forums - View Single Post - EPA
Thread: EPA
Old 02-04-2005 | 11:16 PM
-pkh-'s Avatar
-pkh-
Default RE: EPA
I think they mean you should mechanically adjust your linkages so that you get the throws you want with 100% EPA. This will give you the max torque from your servo for a given throw, and give you the most resolution for controlling it over that throw. If you dial your EPA way down, you loose a large amount of your resolution, and the smaller servo movement for the same throw means you have much less torque than if you mechanically adjusted...
