RCU Forums - View Single Post - LOWERING COMPRESSION
Old 02-05-2005 | 05:32 AM
olgoat
Default LOWERING COMPRESSION
I read somewhere about adding spacers to the head to lower the compression in order to use more nitro. Can someone explain the advantage to lowering the compression to use more nitro apposed to leaving the compression higher and using less nitro? Wouldn't lowering the compression lower the power just to use more expensive nitro to restore it? There must be something I'm missing.
Lonnie
