RE: 130 Flaps
Gunny, the supports look good and should work fine..
One other thing I did was on the floor under the landing gear box I installed 2 ,,,,,,, 5/16 x 5/16 x 36" spruce running length wise and then fiberglassed over them. When I was building the bird and put the wing on the fuse with the gear box screwed down (temporary setup) the floor of the plane had a lot of flex so I put in the spruce to spread the gear load over a larger area of the floor. If you would like a pic. let me know. Jim
Weather here still doesn't allow flying or boating. Yesterday 55 high winds 20 mph.
