RCU Forums - View Single Post - Vectorflight Edge 540 build
Old 02-05-2005 | 09:10 AM
  #690
ckangaroo70's Avatar
ckangaroo70
My Feedback: (51)
Default RE: Vectorflight Edge 540 build
Here is Color Scheme for the VectorFlight Extra 300 for RFG2. I converted it to gif format, so all you will have to do is size it right over top of the stock image by using a program like Microsoft Picture and Publishing. First open the program and then click on the Extra 300. Then use the option "create a new color scheme". You will then be asked to name the new scheme. Once you do this, a stock file will appear in your "Color Scheme" Folder in the "RealFlight" Folder. Open the Color Scheme with your favorite editor, and then import the gif image I have supplied here. Then overlay this image, and size it over top of the stock RF image. Once this is done then just save the file to your Color Schemes folder, and it should work. My Scheme is not perfect, so you will also be able to go back and touch up a few spots you may not like, and also add the VF Extra 300 Plane specs in manually.
