RE: thinning epoxy
IMHO using alcohol from the pharmacy is a big no-no. most of it has far to much water in it and, if you use it often enough as an epoxy thinner, sooner or later you will wind up with a tacky and uncurable mess. The best solution is to use that heat gun mentioned above. If you must use alcohol, be sure it is denatured.
