RCU Forums - View Single Post - LOWERING COMPRESSION
Old 02-05-2005 | 03:34 PM
Motorboy's Avatar
Motorboy
Default RE: LOWERING COMPRESSION
ORIGINAL: britbrat
Removing shims will reduce both the compression ratio & the compression number -- you will lose power.
Hmmm Removing the shims will increase compression ratio and compression number. You must recalculate the compression ratio again.
In Europa are fuel with nitro not cheap therefore we has the engines with higher compression ratio and running cheaper fuel without nitro.
Jens Eirik
