RE: Idle bars, pros and cons...
Idle bars are NOT needed. Most likely the cause of poor transition from low to high throttle is idle needle is not set right,or it could be old fuel or a bad glow plug. If you know you have good fuel and a good glow plug try setting the idle needle in 1/8 turn at a time clockwise. If transition gets worse try turning it counterclockwise until you get a good transition. Goog luck!
