RCU Forums - View Single Post - Draining fuel tank
Old 02-06-2005 | 12:10 AM
HighPlains
Default RE: Draining fuel tank
It should drain better than that. But if you are actively flying (every week or two) just disconnect the fuel lines from the engine and connect them together if you can with a short piece of brass tubing so the tank is air tight.
