RCU Forums - View Single Post - Stripped threads in plywood
Old 02-06-2005 | 11:23 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Stripped threads in plywood
If the plywood is where you can't replace it then you need to fix the hole. Drill out the hole to a larger size and epoxy a dowel into the hole. After the epoxy has set you can redrill your hole and then thread it back to match your screws. Make sure you harden your threads with CA after you get them redone. This will keep them from getting damaged in the future.
Hope this helps.
