Covering techniques (Oracover Lite)?
Ditto! Make sure you tack down the four corners first! If it is a large area (such as a wing) I then tack down the edges, starting between two corners. Do all 4 sides. then tack down between the tacks you just did, and the corners. Keep repeating this until all 4 sides are completely sealed. Then, hit the center with a heat gun (or iron) to shrink/adhere.
