RE: New Cyclone 2m - first flight
Thanks David.
Whats the best way to know how much to lean the bottom end. Just look for a smooth transition? I was about to take 5mm off my header, but I'll try this first. The engine was good straight out of the box, so I want to mess with it as little as possible. Ran about 7700 rpm on the ground, which local wisdom say's is about perfect.
Model is repaired, so although my pride is slightly dented bending it on the first flight, at least now I wont sweat it so much. I love it when you bend a "pretty" model, then you don't have to treat it with kid gloves anymore!
Steve
