RCU Forums - View Single Post - Hitec 5955 problems
Old 02-07-2005 | 12:45 PM
  #65
tobytorkn
Default RE: Hitec 5955 problems
mr. glavin, i've purchased several of these 5955 servos and have a question about programming them. as i understand it, when you set center and the endpoints on the programmer and then remove it, the servo deviates around 2 degrees. my question is does this happen each time and all in the same direction, and is it repeatable. if so, i can still match the servos using the programmer and use the transmitter to set center. if i remember correctly all of my 5945's did this and i just compensated and set each servo with no problem. thanks again. toby silhavy
www.silhavyaerosports.net
