ORIGINAL: tobytorkn
mr. glavin, i've purchased several of these 5955 servos and have a question about programming them. as i understand it, when you set center and the endpoints on the programmer and then remove it, the servo deviates around 2 degrees. my question is does this happen each time and all in the same direction, and is it repeatable. if so, i can still match the servos using the programmer and use the transmitter to set center. if i remember correctly all of my 5945's did this and i just compensated and set each servo with no problem. thanks again. toby silhavy
www.silhavyaerosports.net
While each servo may differ slightly, the offset deviation is consistent of each servo. It simply becomes the programmed center and end-point parameter. There's no need to use the TX trims to set center or end-points, utilize the programmable features of the servos to match the TX. With an iteration method you can and should be doing this anyway.
