ORIGINAL: Angus B
Yes. If you want it to be a high level comp you gotta run it like a high level comp. That means good organisation, good use of time and if you dont take off before 3mins after you connect your glow, tough *****, you lose the flight. Its the only way to get through a lot of flights.
I recall a few years back the unflappable CPLR having difficulties starting an engine at the worlds(i think, mite have been a smaller tourny) and having to switch to number two model with bout 30 secs left to start.
Is there a rough date set for this event?
