RCU Forums - View Single Post - O.S max 46la engine problems
Old 02-07-2005 | 05:49 PM
Montague
Default RE: O.S max 46la engine problems
May be your engine is overheat. Make sure you are using a lubricant more than 18%. Most of the plane in my club use 20-25% of lubricant with OS#8 glow.
Be careful here. Too much oil will cause an engine to run hotter than it should. The reason is that he oil doesn't combust, and doesn't compress, so it raises the engine's compression, and that causes more heat. It may not make a lot of sense, but I've seen this demonstrated first hand.
Also, the reason I didn't suggest an overheating problem the first time was that the engine had been running fine for quite a while. If the problem was heat, I'd expect it to have shown up before. However, if something changed, heat could become a problem when it wasn't before
