Mecoa .32 transition problem
i believe your problem is with the low speed adjustment, this is usually on the other side of the high speed needle (not the screw that hold the throttle barrel), the low speed needle adjusts teh low and midrange settings, while the high speed works only when you have wide opoen throttle.
Regards,
Patrick
