RCU Forums - View Single Post - Poulan 42 test run
Old 02-08-2005 | 12:41 PM
marc morin
Default RE: Poulan 42 test run
The info from Walbro web site says that my carb no: is 11.1 mm venturie size .The quadra 40 with reed valve set up is 12.4 mm venturie size .Do reed valve engines need bigger carbs ?My quadra 40 only pulls a 20 by 8 zinger to 7200 rpm max reliably .
