Pull Pull with Tail servos
I modified and therefore mounted tail servos on my Sukhoi, and still have to install the pull pull cable for my rudder, but would hate to just lay the wires next to the servos and create a friction and/or tension against the servos there. What would be the best solution to avoid this ? Would laying the pull pull wires in nyrod do it ? Also, have you tried to run a long nyrod from almost servo arm to outlet of fuse ? Any input will be greatly appreciated.
