Rigid rod pull-pull
Doesn't the way you've set up your rudder pull-pull with rods present the problem that the control horns must be perfectly positioned to avoid any positive or negative Ackerman? If they were off even slightly, wouldn't it cause the servo to bind? Please explain.
